Results 1 to 8 of 8
    Sep 2018
    Oradea Romania
    Default R270 - Problem BIP BIP BIP
    Hello friends ,
    I have recieved a clone R270 tool. First when i connected was all ok , worked.
    But second time , when connect , starts to BIP BIP and nothing happenes. Even the software don't reconize the unit. Don't show the HW
    Do you know how can i fix it ?
    Thank you
    Oct 2015
    LV
    Look in Device manager for correct Com port...drivers is ok.
    When you connect tool with USB->PC (+external 12V) always will be Bip Bip.
    Check also USB cable, maybe connection not good.
    Sep 2018
    Oradea Romania
    Connection is good. First has been worked. But now, only this stupid beep beep.
    Drivers are OK, 12v supply but nothing.
    Trimis de pe al meu SM-G935F folosind Tapatalk
    Oct 2015
    LV
    look here , maybe it help you:
    https://www.digital-kaos.co.uk/forum...-SONG-BI-BI-BI
    Problem is possible come from not correct port, bad Atmega , or need resold CP
    Sep 2018
    Oradea Romania
    Myeah , probably hardware problem. Saw on that topic , that a guy solved the problem , but never posted the solutions ....
    rob h's Avatar
    May 2011
    Set com port 1
    Nov 2012
    I have one with the same problem.
    I tried to rewrite atmega with dumps from the forum, and now only continuus beeeeeeeeeeeepppp , not bep bep.
    Anibody has a good pair for atmega ?
    Sep 2018
    Oradea Romania
    Tried to modify the com port and no succes.
    Probably is the flash corupted or i don't know.... VVDI Prog is the sollution
