Results 1 to 5 of 5
    Jun 2012
    Default Need dpf offToyota Avensis 2007 2.2 denso 177HP
    Hi need dpf off Toyota Avensis 2007 2.2 denso 177HP ecu nr 89661-05C71, MB 175800-9410. I attached ori and dpf off file. Has someone confirm that dpf off file is correct ? And in this car need to disconnect 5th injector ?
    Jan 2019
    the dpf off is ok 99% and i thing no need to disconnect any thing in this car and according to your dpf off file
    Jun 2012
    Quote Originally Posted by ECU SOLUTIONS View Post
    Thanks for the answer.
    Jun 2012
    Need also remove p0031 from dtc table from lambda sensor.
    How you read this ecu? OBD or on table?
    Some protocols from K-TAG or Piasini?
    I have Avensis with this ECU with removed DPF but when i watch at ECU than like a untouched.
    Temp sensors and pressure sensor is cut from DPF, but no emulator in wirings and no visible signs inside ECU.
    Now I have returned DTC P0400 EGR Flow. EGR valve is new. Now I need disable this DTC and disable EGR.
