Results 1 to 5 of 5
Thread: freezing box
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default freezing box
    wot would make a 500 freeze .. tried flashing with different images and everything . u have to reboot the box and start again ? seems to be getting worse every day . just ordered a new one but would like to sort this one out 2
    cheers
    ps. have a yellow brick so thats ok
    and the others boxes r fine
    Administrator
    Devilfish's Avatar
    Feb 2008
    It's usually a signal problem or a tuner fault m8.
    It could also be a hardware fault. To really know for sure, you'd need to have it connected to your PC with null modem cable and monitor the output in hyperterminal. Use it as normal and when it freezes have a look in hyperterminal and see if it gives any indication.
    Mar 2008
    birmingham
    l starting to think its the tuner , l heard it click today and then if froze and have to reflash and null didnt do it had to ftp and null at the same time and play around with the power for it to send
    Administrator
    Devilfish's Avatar
    Feb 2008
    Sounds like it's on its last legs m8.
    Just as well they're cheap .
    Mar 2008
    birmingham
    will give max_gee a shout and see wot he has
