Do you test speakers / wiring for shorts
alclot (4th February, 2019)
Hi mate. Yes. The problem for sure is in the radio. Any idea?
Asks for code or not?
Check sound IC in case is faulty.
There is nothing works like patience
I worked few time. There is one IC who is heating a lot and you need to take it off, clean and solder again. That worked for me few times, yust one time I need to change that IC. I dont remember label of it, but put picture of a board and I will mark him...
alclot (4th February, 2019), audiopoint (6th February, 2019)
Hi mates,
Sorry my ignorance but where is th ic?
thanks in advance
Hello, I have problem with this one in circle...
alclot (6th February, 2019)
Hi mate, This mcu has the info right? Does it manage the volume?
Thanks a lot
I cant remember his label, i worked them befoure one year maybe... But problem yust like yours and it was problem in that MCU...
did you fix change it for other one? But perharps I need to read before the mcu right?
Sorry beucase it is my firts time.
Thanks in advance
Yust one time I need to change it, 2 or 3 times yust resolder it... Never read, yust swap from another radio, i have one with water inside so I used his MCU and get the sound after changing....
so it happens with lead-free soldering
Lastr question If I want to code donor one what memory I need to change on this board?
thanks a lot
