Results 1 to 7 of 7
    Jul 2018
    Default Can somebody help
    I got BOSCH 06A906018CG ecu its audi 1.8t 1999 year, can somebody tell me can i bench map this ecu with ktag or need another tool, how much i now its me 3.8.3 and i cant find this protocol in ksuite.???
    and witch tool can do this ecu?????
    calibracbr's Avatar
    Aug 2015
    Moon
    You can not read this ecu, it is possible if you desolder the 29f200 memory and read in eeprom programmer.
    Simple way it is to find file online and write it on bench with mpps.
    Mpps can write this ecu, I do a few and it is ok.
  3. The Following User Says Thank You to calibracbr For This Useful Post:
    dainix1990 (31st January, 2019)
    Jul 2018
    OK THANKS MATE
    calibracbr's Avatar
    Aug 2015
    Moon
    Also I have this original file if it helps you.
  6. The Following User Says Thank You to calibracbr For This Useful Post:
    Jul 2018
    DID YOU NOW PIN OUT FOR IT
  8. #6
    calibracbr's Avatar
    Aug 2015
    Moon
    Here it is
  9. The Following User Says Thank You to calibracbr For This Useful Post:
  10. #7
    Jul 2018
    BIG BIG THANKS MATE
