hello guys. i have big problem with one car passat.
i bay this car with broken engine and i change engine. now i have problem with misfire detected. car working with all 4 cilinder good but just fault code coming p0300 and p0304 and p0301. i think somebody play with software. today i read software with ktag. please somebody fix this file good.
vladoford1 (4th February, 2019)
this is not software problem and are you must crazy if you cut dtc with misfire on all cylinders, reapair car.
FILE SERVICE
boomeer (4th February, 2019), vladoford1 (4th February, 2019)
check presure on cylinder
I checked everything. 2 engines replaced all the sensors replaced the fuel pressure checked and eventually found that the computer was recoded 3 times
can you sent pasword now
wrong password
