Results 1 to 15 of 15
    Jan 2009
    Default mazda 6 2.0 RF7K denso 2008 DPF off
    Please need dpf off for this denso ecu
    Oct 2018
    Here, try this....
  3. The Following User Says Thank You to TilQ34 For This Useful Post:
    ziko (5th February, 2019)
    Jan 2009
    Please if someone has tested, because costumer not live here and will go far from here, so must be good 100%
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    Quote Originally Posted by ziko View Post
    "ASC DPF Remover" good work with this ECU (plug connected (need reset oil after mod file flash))
    tell me thanks I will be very happy
  6. The Following User Says Thank You to unnamed11112007 For This Useful Post:
    Aug 2013
    100% ok. Pass PM.
  8. The Following User Says Thank You to kowal5 For This Useful Post:
  9. #6
    Aug 2018
    Nederland
    Default mazda denso master dpf dtc off
    pleas pm for password end thanks my
    no spam in sigs !!!
  10. The Following User Says Thank You to ecuworks For This Useful Post:
  11. #7
    May 2018
    Here you have 100% working solution.
    Password via private Message
    Did it many times on Mazda 6
  12. #8
    Jan 2009
    Thanks to all who helped, I put "ecuworks" file and after flashin ecu DPF was blinking (in ecu no more DTC) so I did DPF regerenation with Delphi and after that DPF goes off and car has power again
    Thanks again
  13. #9
    Jan 2009
    Today dpf light comes again,and car not have power again
    What next?
  14. #10
    N/A
    What next?
    1. Flash with my file
    2. Disconnect sensors (under plastic cover)
    3. Perform a oil reset - u need a wire and second person to help:
    Ready to go
    Pass on PM
  15. The Following User Says Thank You to jenny123 For This Useful Post:
    ziko (13th February, 2019)
  16. #11
    Jan 2009
    Hm, sensors not disconnected,maybe thats problem in my case,but I readed other posts says sensors should be connected.
    Will try as you say
    Tnx
  17. #12
    Jan 2009
    I put jenny123 and did all as you say,after 100m drive dpf flashing again,then I put kowal5 file (before with Delphi reset dpf,flash and reset oil) and till now is ok,will see next days. All sensors remain disconnected
  18. #13
    Mar 2019
    Hello. After stopping the dpf with the swiftec the car has no power. Reset dpf and oil before and after flash. No effect. Can the problem be that the differential sensors are included? Both egt sensors show 700 ° C
  19. #14
    Dec 2011
    PASS PLEASE ?
  20. #15
    Dec 2011
    Quote Originally Posted by kowal5 View Post
    100% ok. Pass PM.
    PASS PLEASE ?
