Results 1 to 4 of 4
    Nov 2011
    Default Range Rover Sport 2006 2.7 TDV6
    The dashboard from Range Rover Sport 2005 till 2013 // 2.7 TDV6 seems to have common problem as :
    1/ The cockpit has sporadic outages, at the same time short control of warning indicator lights and central locking ; after that the engine does not start
    2/ Cockpit has sporadic outages, "system shutdown" message on the radio at the same time.
    Anyone has solution for repair those original dashes ???
    Clone is also an option, but i would like to repair the faulty original...
    Thanks for any advices !
    Mar 2011
    EU
    hi mate,
    Have you find a solution ? I have the same problem and don't want change cluster.
    regards
    Oct 2017
    Reflow the Renesas MCU and all other processors on rear of board, clean all glue off components first, has anybody got power up for this dashboard ?
  4. The Following User Says Thank You to Aislingob For This Useful Post:
    Ocin (27th September, 2020)
    Mar 2011
    EU
    Thank you mate, but I have find solution, I resolder mcu and dash plug, now it work
  6. The Following User Says Thank You to Ocin For This Useful Post:
    sagie1zn (27th September, 2020)
