Hi - I have a 2007 E93. Last year I had the dreaded 9402 error code and with the help of this forum I managed to clear the error code and everything was OK.
It has 're-appeared' about 5 times since the first fix for no obvious reasons with varying durations between the fix, the shortest being 3 hours between it working
and failing again. I suspect it might actually be a faulty controller but I thought I would ask if anyone would disagree? The module is mighty expensive and my fear
is that there is a fault outside of this which I am missing and it would trigger the same error in a new unit.
Thanks in advance for any help or advice!
Cheers,
Paul
