From what component is this? XprogM will read this even is secured (on HC05x adapter)
please mask?
bye martin
hello sogaro,
you need to lift 1 or 2 pins, and don?t remember well.
if you need tell me, tomorrow i tell yopu the pins to lift.
you need to choose a right frequence from upa.
cheers
Sure i do need so tell me all i need to know and if you can take pix and upload , that would be great
Mate none of the mentioned programmers work on this mcu. ETL have originaly designed a special programmer for this type of mcu. You need to remove the mcu a solder to the programmers adapter. We are talking about 68hc705e6 28 pin dil smd right??? If thats the one you will need a special programmer. Hope this helps
0F82B is 68hc05E6 NOT 68hc705E6
mexanico1971 (27th May, 2019)
the connections are that.
mcu upa
1 1
2 7
11 2
12 3
14,15,28 5
then connect 6 volts where the battery are placed. then connect the 5, pin from upa and the 14,15,28 pin to -6 from battery, then at menu from upa you must choose the frequency 2 mhz to read. with that you can read the mcu.
hello
you must lift, or pin 1 or 2, at this moment i don?t have how to check.
and select the 2mhz
