Hybrid View
    Default TUCSON 2006 DAsHBOARD PINOUT
    Hello guys
    I am having troubles to find wiring/pinout to test hYUNDAI TUCSON 2004/2007 Dashboard
    Main problem is with backligth, it no work at all.
    Even when powering ligths things goes worse, because lcd that shows mileage goes off ( it should remain on everytime)
    Car has no problem with the other interior ligthing, I tried also with other dimmer regulation device, but no luck.
    Everything points to a dashboard failure.
    But to check dashboard I need pinout to work with it, but I dont find it!!!
    Even perhaps someone has leaded with this problem before and want to share info with us.
    Really thanks in advance
    bidu20's Avatar
    Jun 2016
    Stecker weiss
    1 Kl. 15
    4
    5 Hintergrundbeleuchtung +
    6 Kl. 30
    7
    8 Hintergrundbeleuchtung -
    9
    10
    11 Geschwindigkeitssignal
    12
    13
    14
    15
    16
    Stecker weiss
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    Stecker grau
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    Stecker grau
    43
    44
    45
    46 Kl. 31
    47
    48
    49
    50
    51 Kl. 15
    52
    not sure..
    Don't forget the magic button !
  3. The Following 3 Users Say Thank You to bidu20 For This Useful Post:
    alclot (7th February, 2019), GolfmkI (8th February, 2019), jeryyy (7th February, 2019)
    Oct 2015
    Attachment 593928
    Try this
    If you found problem, share solution.
    Attachment 593928There are problems in forum, canīt upload image
  5. The Following User Says Thank You to Perryking For This Useful Post:
  6. #4
    Quote Originally Posted by Perryking View Post
    Attachment 593928
    Try this
    Cannot open atachment
    Can you please reupload it?
    TUCSON 2007
    WHITE PLUG (PINS 1-20)
    PIN 1 KL15
    PIN 5 BACKLIGTH 12V
    PIN 6 KL30
    PIN 8 BACKLIGTH GND
    PIN 11 SPEED SENSOR
    GRAY PLUG (PINS 33-52)
    PIN 46 KL31
    PIN 51 KL15
  8. The Following User Says Thank You to GolfmkI For This Useful Post:
    gobe (5th April, 2022)
  9. #6
    Pinout posted by bidu20 is working perfect
    Be care with numbers, they are printed on pcb near plugs (tipical asian cars)
    But is working
    Dashboard seems is working good so 99% Worskshop made mistake and problem is on car.
    Probably 12v or GND for backlight is missing.
