tried this with no success but ensure to have the same file with four numbers of sw version
SGO is not a backup, is compress file .
Every ECU use BIN format ...and (if possible) you can only read BIN.
Then you need convert to SGO
hesham10 (11th March, 2019)
Is it possible to copy the ECU file? If so, which tool?
I have a problem with webasto heater. I have made an update via sgo.file but unfortunately it does not work.
Now I have to downgrade, but "PQ46SH_4730.sgo" is not present in the VW Flash dvd.
I have flash and eeprom only as a bin file, but need sgo.
Is someone able to convert the files to sgo?
You can't convert sgo file. You better use VCP PRO, it's better and easier than VCDS and ODIS
It's possible to download file with vcp pro, and you can flash new from their server, if you have activator
Passat3c (9th August, 2019)
Thanks, but buy extra vcp for the job is too expensive for me. I have already Original-VCDS full version 500€ .
On odis_E I would have access, but unfortunately with odis no dump is possible.
I need a converter to sgo, or someone who can edit the software from the older "4730.bin" to
the new PQ46SH_4941.sgo.
in the 4941, the dosing pump is not activated when i flash it instead of the 4730.
I attach the 4941, if someone wants to take a look on it
open ECU and write directly to cpu ...should be MC9S motorola inside
