thanks god these programs not reconize your file, your dpf off would be trash! theese progams are trash. they work only for some ecus to delete fault codes.
by the way your files are ok.
I bought Kess 5.017 and Ktag 7.020 clone. I installed them and I installed C + 2005, 2008, 2010 Kess 5.017 and Ktag7.020 without any problems getting communication with the computer and the car, reading ID parameters without problems, saving the reader file, comparing the files and always the appropriate size, but the file will not recognize me in ECM Titanium, Lambda Remover 2017.03, DPF Remover 2017.05, EGR Remover 2017.05. As if the problem was
CheckSum.
Kess 5.017 uses version 2.47
Ktag 7.020 uses version 2.23
I installed it on Win XP 32bit, and on another WIN 7 32bit computer, but the same thing happens on both computers.
Of the 5 cars, I only read the Peugeot 307 1.6 16v 2002 that the file was good and that the programs had been recognized.
Now I have a Mazda 6 2.0 RF7K 18 881J service that I need to turn off DPF.
Did anyone have such a problem with the files and how can I rescue them?
Thank you
morgano (8th February, 2019)
people still believe in magic.
Did I ask something wrong or bad? Did I offend you with the question?
I'm glad you did have fun, I do not see what's amusing when someone asks for help, something that is do not understand to him or trying how to fix the problem?
here you have Kess v2 OBD Flash file DPF OFF CS OK!!
pass pM
regards
StojkePN (9th February, 2019)
Mate, i explain, no prob.
Funny thing is wannabe tuners still rely their work on ecusafe, cracked titanium or similar shit, then come here crying for support when they realize they are in trouble.
As i told you before, nothing personal, just let it go, and learn lesson from this thread.
stanislav georgiev (9th February, 2019), StojkePN (10th February, 2019)
Now we understand better, thanks for your suggestions for those programs that I said I would not use them. As for the lessons, you're right, somebody has already done this program with ECU and has done more than good.
morgano (11th February, 2019)
