Key in ECU for sure, but eeprom need read off circuit.
You post eeprom without tiris data, what do you expected?
Rito (8th February, 2019)
Read your key by zedbull, and post tiris data stream from 4C key.
Without that, how someone can check or help you?
Try this file i modifie
Ahh ok thanks to learn about, I never done lost all keys Toyota..
Here are tiris:
I write your dump, but car not start...
Any more solution for it??
Do you have the original dump you read? The posted dump looks like someone already tried to add the key data you posted.
Well, here it is, with the data added as Key 1, using standard checksum algo. Can't tell from this bin whether Toyota uses some variation but it's easy enough to check..
<---- Coin of the Realm.
Yes it are original dump read UPA.
What you think??
Try this seconde key add. Same pass
Your original dumps already magnipulated
Maby ECU is dead, car not start and not do Diagnostic..
Customer fund new ECU and I try done again Key in Key tool Abrites, but not start, but not do Diagnostic.
Can calculate new file to this key??
Tris: 7ED587CA0A000000
00DA417E0000
