1) Open driver's door key removed from the ignition
2) Insert the ignition key and remove it
3) close and open the door 2 times
4) Insert the key into the ignition and remove it
5) close and open the door 2 times
6) close the door
7) insert the ignition key on and off the ignition 1 remove the key from the ignition once
The central lock should close and then open (if it does not do it or you did not fit in times or there is some fault)
8) press and hold the key lock button
9) press the key unlock button 5 times
10) release both buttons and then press lock or unlock
The system should confirm with one cycle of the lock accepting the key
