file is corupt (i think with noread tag) so you cant read it with mpps,so its moded.
I´m the 2. owner of my Signum Z19DTH (150HP) EDC16C9. Who can check this file. I think it´s modded. How much power does my car have at the moment?
I would like someone give me a stage1 tuning with EGR off. Stage1 are 200 HP? Or is it possible to get 2 Files. one with 190 and one with 200 or more?
I need the file for OBD MPPS V16.
Thx Jarnsen
Jarnsen (10th February, 2019)
How can I read the ECU? What is the easiest way to get a Stage 1 with EGR off for my car. I have 3 cars with the same Engine. Hopefully the same ECU. 2 Signum and 1 Vectra.
jarnsen
I´m not sure. Is it a EDC16C9 or a EDC16C39? I read this Data with OP-COM
Kennung: 0x0739
Fahrgestell Nr.: W0L0ZCF4XXXXXXXXX
Hardware Nr.:81011915
Motor-Typ: Z19DTH
Teile Nr.:55193967
Softwareversion Nr.: VNOMS090_S
Herstellernummer: 0281011915
Software Number: 1037384325P319_O83
Programming Date: 20080905
Hardware Schlüsselnummer: S001002280
Sys-Beschreibung: BOSCH0100
Typkennungs Nr.: B04017
Variant programming: 0x000050B0
Alpha Code: YY
Hersteller: EDC16
Software version: O83JTD74
ECU variant coding: 0x0000F9C0
Who can help me with a file.
I would like to write with KESSV2 o MPPS.
Thx Jarnsen
try to read with kess.
If i read out with KESS and EDC16C39 ID or READING there is nothing. Reading error.
If i read out with KESS and EDC16C9 only ID works.
HW: 0281011915
SW: 1037384325
VIN: W0L0ZCF4XXXXXXXXX
SW Ver.:
Teile:
Motor: Z19DTH
HW Ver.:
SW Upg.:
Anlage:
If i read out with MPPS and EDC19C39 or EDC19C9 it´s the same.
ID with MPPS
EDC16C39
Vehicle Vin Number: W0L0ZCF4XXXXXXXXX
Bosch Hardware Number: 1037384325
Bosch Software Number: 0281011915
Opel Software Number: 5519396
Engine Type: Z19DTH
And Reading with MPPS is in the Attachments.
If i compare MPPS and KESS ID then Hardware Number and Software Number are swapped.
I hope someone can help me with my problem.
THX Jarnsen
@kaadzis
did you look over the data again? Did you or someone else have an idea for my Problem. Can i use an other file?
Thx Jarnsen
What you read is 35 kb. Replace the tool and read a full BDM
I know. There are only 35KB. Because the ECU is moded. I Havn´t a BDM reader. Is there a way with an other ECU file from the similar Engine? I have 2 more Z19DTH here.
Or how ist the best way to read full BDM. With a KTAG? Or is it possible with a KESSV2?
THX Jarnsen
Read to learn what tools they read Full BDM from ECU
