if someone can help with me7.1.1 ecu not responding after boot write with ktag
Results 1 to 3 of 3
    Aug 2016
    Default if someone can help with me7.1.1 ecu not responding after boot write with ktag
    i have a issue if anyone can help, got 2 ecu faulty water damaged from bentley 2004 bosch me7.1.1 . but manage to read original file with ktag through bootmode. i clone these over onto slightly different me7.1.1 , boards are identical however bosch no. different. after clone now donor ecu's got no comms and i can only read in boot mode. if someone can check my files and advice me to fix this ecu.
    original ecu Bosch no. 0261208182
    donor ecu's bosch no is 0261207018
    i dont have the donor ecu backup so if someone can give a bdm will be usefull to write back and see if it wakes up?
    0261207018
    thankyou
  2. The Following User Says Thank You to garagetech007 For This Useful Post:
    boost turbo (13th November, 2022)
  3. #2
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    try here man
    http://www.chip-tuner.hu/original_ecu_files/files/Audi/
    press thanks button and reput if i help
    Aug 2016
    thank but cant find the file im looking for
