Send to me cpu1,cpu2,esl,ecu dumps.
Feri
I greet problem with programming of key on Mercedes IR in nec. If i try program key nr 2 remote control working but if
i push in to ignition nothing happens only led in key
is on in 3 sec. When i try coded key 4, if i will put in
ignition then led is on 3 sec and after blinking.
Please help my how correct program key, maybe any
solution. Car its 99y merc 208, inside hc05x32. To generate
bin file in to nec i use ir programmer codemaster 2/2008.
I Salute
Szym
Best Regards
Simon
Feri
Remote works means EZS is programmed ok.
led blinking means synchronizing.
If ecu is not virginised it keeps synchronizing and never stops.
if you can turn on ignition then ESL is ok, if not then keycode is not programmed in ESL.
Means: you should viginise ECU or program keycodes in ESL.
