Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 73
  1. #16
    rola1971's Avatar
    Jun 2014
    Dublin
    i have x8 maybe 3 year.it park in car and work only for AKL situacion.3 year and still work dont have any problem.in workshop i used Miracle A9 3 year and no verry happy.this moment buy condor mini plus.
  2. The Following User Says Thank You to rola1971 For This Useful Post:
    Faraday (19th February, 2019)
  3. #17
    Oct 2013
    Quote Originally Posted by Weasel3 View Post
    What happened with your sec09 machine?
    Isn't it possible to get any spare parts for this one.
    The X8/V6 is a really downgrade from this one.
    You cant get the Dolph yet. It will not be available for quite some time.
    If I was in your situation, I would try to get spare parts. Did you ask the factory for support?
    Seller told me that Dolphin machine Will bč ready within March.
    I prefer buy new Key machine...because i repaired sec9 many times...
    I am choosing between mini plus or dolphine...i want avoid to buy x6 or sec 9 and after 1 year buy again a Key machine...i Need machine for duplicate and keys Lost situation...
  4. #18
    Feb 2014
    As I said differences are obvious. If you can live with it then you can buy it.
    For me using your phone for key cutting is a bit limiting - you can't go outside because it will loose sync and may influence the cutting. Better option will be to dedicate a tablet only for the machine.
    But still it is a smaller, more economical machine. So it will better serve those with lower level of workloads.
    But no one seems to have really tested this machine outside of China (because it's still in development phase), so you will be the first to share his opinion, it seems.
  5. #19
    Oct 2013
    This i morning i ve talked with sec9 support, machine Need another motherboard...It Can died on workshop s bench
    The condor dolphin machine Need One month...
    I must choose between xcmini or xcminiplus...if i choose xcmini the clamp for Ford tibbe keys (fo21) is included...and i can Save a bit of money...
    Or i can buy last model of condor...
    I Need your suggestions!
  6. #20
    Feb 2014
    No more suggestions, it's all laid out. Time for your decision.
  7. #21
    Jan 2018
    CA, USA
    i have the condor mini, and i love it, only issues ive ever had was cutting hu58 (key worked still but cut shoulder where it shouldnt have a cut) and recent updates gave my condor a few issues, but latest issue fixed everything and now works perfect like it did before the last few updates. i plan to purchase the dolphin, easier to transport and runs off battery (i can power my mini with a powerstation, but rather 1 less thing to connect).
  8. #22
    Feb 2019
    I got the Condor Mini and works ok sometimes, It has broken a few probes/tracer with no idea why. Even calibrated prior and still broke a few probes on Honda cuts and a 1.5 drill on a Mitsubishi, it just goes through the key as if there wasn't anything there. It's done it a few times, then I started using Instacode from my phone to send the decode and cut commands and at least it hasn't broke any so far. So seems it's ok for now.
  9. #23
    Feb 2014
    Well... obviously it is not supposed to do that.
    Did you reach support about this issue?
    It sounds like a problem with grounding or electrical conductivity.
    I had similar situation on a different machine. Solved with extra cable to ground the key clamp on the inside.
    Oh.. and I think in the service menu there was a conductivity test to check if this is the issue. Did you try it?
  10. #24
    how many keys do you expect to be cutting a week/month ?
    i have the x6/v8 and it works great for the occasional key job.
  11. #25
    Feb 2019
    Quote Originally Posted by autoTkey View Post
    Haven't done the conductivity test, I'll give it a try just to make sure everything is in order. If it keeps breaking the tracer I'll contact support. Cause kind of sucks
  12. #26
    Jan 2018
    CA, USA
    Quote Originally Posted by DigitalBacon View Post
    something definitely off ive cut many hondas and the only time i have broken a tracer is when i was decoding a key i forgot to clean the key off and so when it was decoding, the dirty key had some gunk on it and the tracer did not make conductivity and broke. now i make sure i always brush off the key and expect make sure nothing that will block it from making ground .
  13. #27
    Feb 2014
    Yes, that's a very important step before you put a key for decoding.
  14. #28
    Jan 2017
    USA ����
    i only broke on rangerover aluminum key it has hard coating must scratch key to make conductive
  15. #29
    Jun 2015
    United Kingdom
    This new cutting machine from CGDI, cg godzalla, I think its likes to Condor Dolphin hiahiahiaihia
  16. #30
    rob h's Avatar
    May 2011
    Looks good, with display and phone function, for that price!
    Been very happy with what cgdi provided before, and the updates.
    So i,m looking forward to this machine.
