Hi i have a problem reading med17.5.1 with ktag clone.
It has no probe connection in ktag so don’t really dare using the probe as with other EDC/Med17 ecus that solution worked several times.
So for this ecu ktag says connect with cable. I was so confused i ended cutting my cable and soldered it to the pins to make sure it had good connection.
Even after this i still get this error
I am feeding it 12v 3a should be enough and as mentioned before been used on several other ecus from same family.
The cable i was told had a problem on clones the can wires should be switched so even that solution i tried.
So right now i am at a point with no more great ideas. Is anyone able to help me with a possible solution to why this want read.
Ktag PCB
