Results 1 to 4 of 4
    Default Nissan X-Trail rpm problem and rough running
    Hello, I have a big problem with a Nissan X-Trail 2.2 diesel that occasionally runs rough and the rpm indicator is bouncing. It is a strange problem that I haven't encounter before. I uploaded a youtube clip in order to better explain the symptoms. The cam and crank sensors are new and original. I have also rewired both sensor to eliminate wiring issues. The link to the video is : https://www.youtube.com/watch?v=diFBvzlpJp4
    Any advice is appreciated !
    Thank you !
    Meat-Head's Avatar
    That's weird like ecu , what fault codes but no engine light on , your also during on wrong side of the road
    z3alin
    3
    Downloads
    Uploads
    No error codes most of the times. Occasionally had the cam sensor show up as error code and that is why it was changed. I will try with new ecu and report it. Maybe it will help others.
    Meat-Head's Avatar
    Could also be looking at your video ground wire insulated by unread dK posts
