hi all
i have this vw polo from 1999 whose key doesn't work anymore. i tried to read the immo but the cluster is locked.
any ideas?
hi all
any ideas?
Hi my friend, what is the eeprom in which is in the dashboard
in the dash i seen a 24LC08. I didn't open the ecu yet
Why not program a MEGAMOS 48 transponder to start the car
Post eeprom 95080 from ecu and i do it without immo .
regards
Read the pin for m the ECU then you will have to leave ignition on for 20 minutes before coding key
i still try to find a way to read this 95080
is hard to be a newbie in programming
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
ok this is the beast stripped
on the back side i think is the resonator that must be shorted in order to read the eeprom (as said here: http://www.codecard.eu/prod_48.html) but i am not so sure
unsolder this memory and read
send file here
som friend help u 100%
no file no help
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
uadi (17th February, 2019)
my carprog don't seems to read this eeprom.been tryng for 2 days now. any other programmer?
