finally my carprog is back and i managed to read the 95080 eeprom. any ideas?
can someone help me with immo off on this polo1.4 magneti marelli?
I does not says which region the vehicle is located EU, US or other places.
But I guess it is EU.
Check that your keys is identified with ID42, and not an empty key.
Then if you have looked in the cluster. You are looking in the wrong place.
This one has a black box under the dash. You need to read out the info of a TMS processor 28 legged with a programmer to get the PIN.
In this case you should be able to get a second hand box and solve it. If the box have some error.
[Select]
[25 - Immobilizer]
Look at the "Component" field. The 14-digit string in the Immo-ID.
I am quite sure that this model has no PIN in the ECU.
Swap go easy.
Need just immo login and immo chip if you not have this.
uadi (6th April, 2019)
Then you are in luck, less work with this one..
Yes you can.
Vehicle must be produced as a early 2000 model.
Your ID would be 44 instead.
uadi (2nd April, 2019)
i read the 24c04 eeprom
is the pin inside?
