her you go
don't forget press thanks & Reputation
her you go
Don't Forget press Thanks & Reputation if helped
Thanks, but I have written: Carprotool solution not working!!!!!!
Sorry...
Other solution?
Astra J crash can be cleared with diagnostic equipment too..If you have launch for example,or op com.
Thanks. Nice.
I wanted first this.
Not possible. Probably 2 or 3 crash events were.
Other solution?
Stelaras26 (15th February, 2019)
Hi Magyar, check this clear manually ...
Best regards.
Dragon
Thanks, but not working.
Other solution?
Which errors ?
Best regards.
Dragon
Crash data stored..
Not possible clear via OBD..
If you still need, check this ...
Best regards.
Dragon
Thanks but unfortunately not working.
Problem is same: 25 faulty with B0052 deployment commanded.
Somebody can help me?
Check if you want ...
Best regards.
Dragon
Thanks, but problem is same. Crash data found, not possible clear via obd..
