Try and report
Hi all !
I have a problem with a dashboard from traffic 2011 with 93c76.
With the first dashboard, i have remove eeprom from dash, then modify it with nyo2017 and resolder the eeprom on dash but when i put in the car, no light at all, the dash seems to be dead completly.
With a second dash, i wrote file of the eeprom of first dash in eeprom of the new, this time all light working but on the top screen no info at all but screen work with orange light but no info at all on it.
then i have try to modify ori eeprom file of the second dash with nyo2017 but when i put the second dash on the car, same results all light working but no info at all on the top screen.
Ihave read some similar case with problem with thios particular dash.
Do you think nyo doesn't do the job well ?
Here are my two files, one with 260000 km and one with 64000 but i need 213583 please
Can anyone help me please ?
Thx in advance and have a good day
Try and report
Progdebutant (14th February, 2019)
Thx you very much friend, just for information, with which software did you that and for you the dump i have made are good both ?
And by the way, do i need to swapbytes files or anything before writing into the eeprom ?
upa 1.3 is good
i have upa usb but your files seems to be not ok, in nyo it says both files are 260000 and i need 213...
anyway thx to you but anybody can help please ?
i have made files with nyo, carprog is it better ? i have it too
sory
Try and report
Progdebutant (16th February, 2019)
thx but with which software did you use to do that ?
if its nyo or carprog i have both
Hi all
i have try to make the file with tachosoft using algo from kangoo 2008 with 93c76, i have change bytes like tachosoft show, i have made two files.
one which i have only change required bytes and another one with change required bytes and swap.
the two files not work, all light ok but in top screen display, no info, only orange light on all the screen.
my question please, if i make file with tachosoft, do i need to swap the whole file or only bytes i have change ?
Please answer, thx in advance
old 64443
new 213583
Hi all,
thx for your files but i have exactly the same with nyo2017, i have wrote files in swap mode and normal but always same problem all light ok but no display on top screen at all
Maybe version of software on dashboard is a problem ?
i have wrote file off the old dash in new but one dash is 2011 and the another is from 2014.
i will try to rewrite ori files of the new dash instead of write files of the old one.
anyone have suggestions please ?
please help
