Flip key pcf7961 ASK type Peugeot 207.
No flip key pcf7936 ASK pcb inside paired with PCF
You can use pcf7961 Chinese key type Peugeot 206 if remote not working change type on bsi
Envoyé de mon iPhone en utilisant Tapatalk
Hi.maybe anyone can help what key should be on this car.
Citroen c2 2004-09
Vin VF7JM8HXC97168613
All i know its not flip key. 2 button,key blade va2 ordered by vin.
Need pcf type and ask or fsk
drugowaz (15th February, 2019)
More specific what to change on bsi?
Key blade by vin
https://imgur.com/a/nOLhuZk
So ori its not flip .
Maybe from KD any key will fit?
Data for remote for example if your car 096A you need to change to 05A5 for Chinese remote key. If you add new original key don’t change anything remote work.
Maybe this will fit
https://imgur.com/a/tAcEQEH
Yes but original key have pcf7936 and pcb for remote. And Chinese keys have PCb with antenna and pcf7961.
Yes i get that. Thanks for tips
citroen c2 2005-2009(can bus) use flip key,for kd use 0536 NB Multifunction ASK
Ita k line car
Tested maybe 5-6 kd
Including pcf7961 ask
Non of them work remote part
today i am out of the shop,tomorrow when i will be back i will check my notes if i have done a kline and post my friend
drugowaz (18th February, 2019)
Not have time play such deep,conected lexua not even com by diag on bsi,maybe wrong build number input . I ofered service key . He not wanted. So i left job.
keydiy PSA CIR43 programmed with sbb ok
drugowaz (19th February, 2019)
[QUOTE=newone;3505359]keydiy PSA CIR43 programmed with sbb ok[/QUOTE
Remote separate program or instant with immo?]
