Results 1 to 1 of 1
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Question ross tech vcds help
    Hi I am new to ross tech vcds does anyone know what these codes mean passenger door and passenger rear door would not open got passenger door open and changed lock both doors worked ok today rear passenger opens front will only intermittently.
    this is what I get.
    Friday,15,February,2019,10:22:09:59248
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.0.2
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: WVGZ License Plate:
    Mileage: 186680km-115997mi Repair Order: 1234
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ7W043035 Mileage: 186680km-115997miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.clb
    Part No SW: 03G 906 021 MM HW: 03G 906 021 AN
    Component: R4 1,9L EDC G000SG 0511
    Revision: --H06--- Serial number: VWX7Z0G03NM1K3
    Coding: 0000072
    Shop #: WSC 01324 785 00200
    VCID: 76E3399C01204DFAFF-8022
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021190
    VCID: 73E50088125258D2D8-8026
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
