Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 102
  1. #16
    Top Poster andresfn18's Avatar
    Mexico D.F.
    Default IT`S NOT READING!!
    I TRY TO READ A DASH FROM 2009 AND IT DOESN`T WORK
    I HAVE TO READ WITH TMT X-PROG!!!
  2. #17
    Mexico D.F.
    I SEND THE LOG!!! TANKHS!!!
  3. #18
    Hello!
    i think i would buy The AVDI hardware plus options for VAG.
    think you it was a good device for cars.
    and from which company is it better to buy
  4. #19
    Quote Originally Posted by mlulic View Post
    I buy from Arbitus72 vag k can comander v7.1. Vag k can comander have 21 special functions I buy 9 functions
    Special functions
    AN001 Base Hardware
    AN002 KM CAN
    AN003 PIN CAN
    AN004 im*o data
    AN005 im*o data in ECU
    AN006 K-Line
    AN008 ECU/Flash/Counter
    AN009 Key Learning
    AN010 Airbag
    AN011 TV activation
    AN012-A ECU EDC16 km
    AN012-B ECU EDC16 sec.access
    AN014 ECU EDC17/MED17 sec.acc
    AN015 ECU flash
    AN016 Dealer Key Learning
    AN018 Dealer Key learn Q7
    AN019 Prepare Dealer Key Q7
    AN020 Transponder Programmer
    AN021 ECU eeprom 2
    Standard diagnostic functions:
    • Connect to the device using KWP2000 over TP2.0, KWP2000 over TP1.6, UDS over ISO transport protocol (CAN), KWP1281 or KWP2000 over K-Line
    • For all electronic control units reading identification data
    • For all electronic control units read error (DTCs)
    • For all electronic control units clear error (DTCs)
    • Scan all units
    • Broadcast requests
    • Measured values
    • Adaptation
    Now is name AVDI
    Hello.
    I have read that you have the AVDI interface.
    where this a good tool for all VAG cars to read login and adjust KM
    Are you satisfied with this tool.
    From where did you buy this tool, can you say me the homepage name.
    Thanks you
  5. #20
    ...where was Columbus
    Default Abritus
    www.abritus72.com
  6. #21
    thanks, that is a great help
  7. #22
    somebody make summ of all option ? It cost a lot of $$$$
  8. #23
    Top Poster + jimthejock's Avatar
    Scotland
    Default Abritus and Vag commanders info
    this is a pdf of the prices this month
    Jimmy
  9. #24
    Quote Originally Posted by jimthejock View Post
    THIS IS NOT PDF FILE!
  10. #25
    impactops's Avatar
    Quote Originally Posted by Air View Post
    it is a PDF
  11. #26
    hi. i have the software Avdi + 4 options for vag.
    the software was really the best. what they say they are go.
  12. #27
    H.Wessel's Avatar
    hi
    be carefull, the interface have inside a battery, when battery flat out advi interface dies..not nice
    another hidden trick, you can?t use the advi interface in the same clauster 10 times, if you do it will block (pirate)
    price is high, at last for old edc15 and edc16 functions which had been cloned by chineese,
    expensive but good device,
    best regards
    H.W
  13. #28
    H.Wessel's Avatar
    I have a photo of the two versions of avdi interface, here is it :
    http://img696.imageshack.us/img696/5811/avdihw.jpg
  14. #29
    DiegoAC's Avatar
    Well, if you want the full package for the main brands (MB, BMW, VAG, Fiat, Renault, Opel) it`s around Euro 25.000 ...
    Daaaamn.
    Quote Originally Posted by marinero123 View Post
  15. #30
    Apr 2009
    full software Abritus 1 end 2 / 10 rar
