I have vag k+can commander v3 from china and so far its been useful in erasing crash data fom 2002ish seat, and getting pin code for 2000 passat from instrument cluster that my super mvp couldnt read. Hope its the sort of answer you required
the best product on the market and getting better.have a look at Abritus72,new christmas offer save 1000 euros
Hi I am also interested in their products.I know they are extremely good on the immo side,what about the diagnostic side of things ie actuator functions,live data,etc.Does anybody have the new AVDI system from them?.It includes all the commanders in one unit.What are the views on their stuff.AVDI seems like a good buy
I buy from Arbitus72 vag k can comander v7.1. Vag k can comander have 21 special functions I buy 9 functions
Special functions
AN001 Base Hardware
AN002 KM CAN
AN003 PIN CAN
AN004 im*o data
AN005 im*o data in ECU
AN006 K-Line
AN008 ECU/Flash/Counter
AN009 Key Learning
AN010 Airbag
AN011 TV activation
AN012-A ECU EDC16 km
AN012-B ECU EDC16 sec.access
AN014 ECU EDC17/MED17 sec.acc
AN015 ECU flash
AN016 Dealer Key Learning
AN018 Dealer Key learn Q7
AN019 Prepare Dealer Key Q7
AN020 Transponder Programmer
AN021 ECU eeprom 2
Standard diagnostic functions:
Now is name AVDI
- Connect to the device using KWP2000 over TP2.0, KWP2000 over TP1.6, UDS over ISO transport protocol (CAN), KWP1281 or KWP2000 over K-Line
- For all electronic control units reading identification data
- For all electronic control units read error (DTCs)
- For all electronic control units clear error (DTCs)
- Scan all units
- Broadcast requests
- Measured values
- Adaptation
Does it have actautor functions like a/c clutch power on,radiator fan power on etc
vag k can comander I not used for diagnostic(he have base function
Scan all units
Broadcast requests
Measured values
Adaptation
I used for the diagnostic VCDS
yes I confirm that
does somebody know is it now possible to read pin from Golf V after 2006 -2007 by abritus??
Could you lay out the original soft 7
Hi....
the new update from abritus72:
Abrites Commander for VAG 7.7 released
* Added support for VDO Instrument Cluster 2006+
Mileage recalibration
can someone confirm this....!?
Can this update read pin code from immo Golf above 2006+ or odometer correction...!?
thanks for info and reply...
regards
bigdiez
