Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 126
  1. #61
    Romania
    Look at this ,also read problem.
  2. #62
    Aug 2010
    Hi attilaa0
    It seems I have same problem.
    What tool are you using ?
  3. #63
    Romania
    Quote Originally Posted by baleyba View Post
    Hi attilaa0
    Your message box is full.please clean it.
  4. #64
    EU
    Read problems in circuit i had with T420 laptop which uses the Ricoh native card reader that is able to access boot and rpmb partitions.
    With emmc unsoldered from board i had no problem.
    For read in circuit use better one Sd to usb adapter , it should work.
    Sent from my iPhone using Tapatalk Pro
  5. #65
    Sep 2015
    please
    someone can tell how to read the emmc data once recovered.
  6. #66
    Aug 2010
    I succeed reading mmc.
    I had bad contacts on PCB.
    But it is not enought to restore unit.
    Please could you confirm flash is inside S9S08 ?
    thanks.
  7. #67
    Romania
    How did you read it?With programmer or card reader.
  8. #68
    Aug 2010
    Hi attilaa0,
    With simple USB card reader.
    only with dat0 line
  9. The Following User Says Thank You to baleyba For This Useful Post:
    attilaa0 (24th May, 2020)
  10. #69
    Romania
    Hi attilaa0,
    only with dat0 line
    Thanks!But in this way obtain folders,not a bin file.What capacity is the readed files?
    Did you cleaned your private message box?Last time was full.
  11. #70
    Aug 2010
    Yes pm is empty now. Sorry.
    I used emmcraw tool to make read full in RAW format.
    I got 8Go file
  12. The Following User Says Thank You to baleyba For This Useful Post:
  13. #71
    Sep 2015
    you have to supply the unit with 12v or not?
  14. #72
    Aug 2010
    not needed
  15. #73
    Sep 2015
    can give you more details on how to read emmc and with what tools, i can't read emmc, my computer detects the memory card for about 2 seconds then it disappears from the manager. i use a simple card reader , is it that it can come from the reader.
  16. #74
    EU
    Quote Originally Posted by wamba16 View Post
    Read the topic, here are all the details on how to read the emmc.
    Post some pictures of your connections , give more details of what are you doing.
  17. #75
    Jan 2020
    Germany
    got a Mib Std2 ZR 5QA035858A unit where I need to remove component protection or adapt to my vehicle.
    I dumped the emmc memory, flash an eeprom.
    Can we remove cp in emmc??
