Hi attilaa0
It seems I have same problem.
What tool are you using ?
Hi attilaa0
Read problems in circuit i had with T420 laptop which uses the Ricoh native card reader that is able to access boot and rpmb partitions.
With emmc unsoldered from board i had no problem.
For read in circuit use better one Sd to usb adapter , it should work.
Sent from my iPhone using Tapatalk Pro
please
someone can tell how to read the emmc data once recovered.
I succeed reading mmc.
I had bad contacts on PCB.
But it is not enought to restore unit.
Please could you confirm flash is inside S9S08 ?
thanks.
How did you read it?With programmer or card reader.
Hi attilaa0,
With simple USB card reader.
only with dat0 line
attilaa0 (24th May, 2020)
Yes pm is empty now. Sorry.
I used emmcraw tool to make read full in RAW format.
I got 8Go file
you have to supply the unit with 12v or not?
not needed
can give you more details on how to read emmc and with what tools, i can't read emmc, my computer detects the memory card for about 2 seconds then it disappears from the manager. i use a simple card reader , is it that it can come from the reader.
got a Mib Std2 ZR 5QA035858A unit where I need to remove component protection or adapt to my vehicle.
I dumped the emmc memory, flash an eeprom.
Can we remove cp in emmc??
