Results 1 to 13 of 13
    Aug 2018
    USA
    Default 2015 Ford Fusion spc5606s
    I try with xtool but its filed security and fvvdi 2018 no luck, old mail 76k
    new one 56k, i red it with vvdiprog.
    thank you
    Mar 2017
    Colombia
    Your Reading Is Good, I See; VIN: 3FA×××××××24. Km 12××××, mll 75×××
    but you must try it with for OBD. OBDStar, Smok, X-100, X-Tool
    WINNER THE LOSER
  3. The Following User Says Thank You to automotrizVIP For This Useful Post:
    hai82der (15th February, 2019)
    Aug 2016
    EURO-KOLCHOZ
    you tried by x-tool or Chinese xtool ?
    because I did it once using an x-tool
    Quote Originally Posted by hai82der View Post
    thank you
  5. The Following User Says Thank You to jetronic30 For This Useful Post:
  6. #4
    Aug 2018
    USA
    its xtool pad2, its say filed security , i will try it agine with xtool, I tried with carprog clone 2015 not active, Im witing for my new carprog original coming Monday I hope its will be active.
  7. #5
    Aug 2016
    EURO-KOLCHOZ
  8. #6
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    thank you
    The reading is in miles? you can try this if reading of your ODO is in mIles
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  9. The Following User Says Thank You to hcip For This Useful Post:
    hai82der (16th February, 2019)
  10. #7
    Aug 2018
    USA
    i try it with vvdi pro but now its say writing error and i lost the file only first line showing ?
  11. #8
    ELAURINO's Avatar
    Sep 2018
    i doit with xpad 2...ok
    tray with another model car...first backup
  12. #9
    Aug 2018
    USA
    do you thing after every think was erased its will work if i try it ?
  13. #10
    ELAURINO's Avatar
    Sep 2018
    try it ,,,, pero primera copia de seguridad
  14. #11
    Aug 2018
    USA
    its not let me backup. this the reading now
  15. #12
    hcip's Avatar
    Dec 2009
    I think VVDI has problem writing the MCU.
    I always use UPA-s with this MCU without encounter any problem in reading and writing
  16. The Following 3 Users Say Thank You to hcip For This Useful Post:
    automotrizVIP (16th February, 2019), hai82der (16th February, 2019), ker0sin (12th August, 2020)
  17. #13
    Aug 2018
    USA
    Thank you to everyone whow try to help me, finally I solved i fond out the volt was 3.7 so I change it to 5 volt, and pum work good.
  18. The Following User Says Thank You to hai82der For This Useful Post:
