Results 1 to 7 of 7
    Oct 2015
    Default Fiat Stilo Power Steering problem
    Hello everyone
    I have problem with a Fiat Stilo 1.6 16V 2003. The problem is with Power Steering Module. After i disconnect the battery and connect again i have problem with this module. The red light of Power Steering stay on and the Steering Wheel is hard to turn it. I think it have need to recalibrate. I have read flash and eeprom from this ECU. Can anyone verify if it is correct or not, or have anyone another dump file for this ECU.
    the problem is not in the program the problem you need to change the steering sensor inside the steering its most common problem
    Oct 2015
    A flet shqip ?
    Aug 2018
    East Pole
    Hello, if lirinikut has roght, change the steering ribbon, but if is not the problem, avdi can solve the thing with relearn
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    have you make a diagnosis?
    what is the fault code?
    May 2019
    hello, can you tell me how you read the st10?hello, can you tell me how you read the st10?
    Newmotors's Avatar
    May 2019
    brazil
    st10 flash programmer !!! ou ktag, galetto etc.....
