spiridonas (29th March, 2019)
If you have the exact old value, try doing mileage correction with that exact value and see what happends ... if still ----- then dump corrupted
Check if VIN is correct in BCM and Dash.
Wysłane z mojego VTR-L29 przy użyciu Tapatalka
cristi_bv (13th March, 2019), spiridonas (29th March, 2019)
try to write original in dash then work only in bcm, I have done so and never had problems
So just to my knowlage, i dont have X-Tool, just Smok but not activation to opel/vauxhall so will prefer dop it on bench..
So which module i should change millage? just BCM or millage is stored in Cluster as well?
My post helps you? Please Hit Buttons
Hello, I am new to this forum, I recently got a same issue when I changed the IPC, how can I use these files to fix the issue?
James
I have same problem any help friends
Everybody need help..but where is dump?..eprom or mcu type...dash manufacturer....etc ?...how we can quess all this things ?
Upload files pls..maybe i can help...
eprom 24c16 from bcm
opel corsa E 2015 The mileage shows "------"
best regards
Your mileage is 40031km
Try this file..maybe will help ...
And why you ask Astra H 2017 and file name is Corsa H 2016 ?
I'm confused a litle bit ...
Thanks Friend I try and report . I guess I wrote this because one of diodes fly away when i tried to remove the eeprom from bcm
if you have MDI - i can help you remoute
Activation GDS2 Opel, Chevrolet, Saab, Global
Help with GM SPS. Activation-deactivation any options.
