Results 1 to 4 of 4
    Feb 2018
    Default DAF DIP - 4 Dash pinout, wiring
    Hi!
    Please, can someone help?
    I need the pinout/wiring for DAF DIP - 4 14pin instrument cluster. If i'm right, it used in XF105 for example.
    DAF Nr.: 1789469
    Supplier:SiemensVDO Automotive AG
    Typ: 155.04050302
    Nr.: 446804
    Thx.
    lucianh's Avatar
    Oct 2014
    East Europe
    What do you want to do?
    If I helped you, please, use the
    reputation + thanks buttons .
    Thank you!
    Feb 2018
    I want to wake it up on bench (mostly the display), and I hope it requires just the GND, Battery+ and Ignition switch.
    Oct 2020
    Do you know the pins of this cluster? i know that pin 1 is positive and pin2 gnd. But can someone guide me what are the other pins.
    I have a cluster that the batteries has been connected wrong. I had found the transient diode and the positive diode shorted. When i put positive and negative on pin1 and pin2 it will not switch on.
    I appreciate any help.
    Thanks in advance
