Results 1 to 9 of 9
    Dec 2018
    Default Mercedes A170 CDI (w168) won't start - P1187
    Hello everyone,
    I have MB A170 CDI 2002. The engine won't start.
    I read it with Delphi DS150E and DTC is P1187.
    I checked the high-pressure pump through live sensor data and while cranking pressure is about 20 bar and the car won't start. I tried to start the car with start spray and I succeed at that but only for a second or two and engine immediately stop and P1187 error appears. At that moment when the engine starts, I have ~330 bar pressure in rail but engine often immediately stop and the max pressure is about 60-80 bars. Only one or two times I succeed to get ~330 bar. So I'm hoping that pump is OK but something else command ECU to stop the engine ASAP.
    The rail pressure regulator was changed and it didn't help.
    Any ideas about what else can be a problem or how to fix this problem?
    workshop
    check injektoren
    Jul 2013
    yorkshire
    60-80 bar is not enough. Check low pressure from tank. No low pressure = No high pressure.
    Dec 2018
    @mercis
    Hey, I forgot to mention. I removed inlet manifold so I can perform an injectors leak test. I cannot start the engine so I can't test leakage on idle but while cranking there was no leakage.
    @autoden
    Yeah, I know, but the pump doesn't have enough time to get ~300 bar because ECU immediately stops the engine once the engine is successfully started with start spray. I mentioned that few times I get motor running for few seconds and then the pressure is ~330 bar. I'm not sure if A170 CDI has the low-pressure pump in the tank? Next to the high-pressure pump, there is a low-pressure pump and it's OK.
    workshop
    you must injektor test,out car
    May 2018
    Ukraine
    Check fuel flow from injectoren and rail return, at startup. If present, see DRV valve and ijectoren, if not present, see shut-off valve.
    Dec 2018
    @mercis,
    The only way to perform this is to remove injectors and test on machine because I cannot start the engine, right?
    @mihac
    By "DRV valve" You mean Rail Pressure Regulator? It's replaced and it isn't a problem... While cranking there is a lot of fuel in return pipe but it's coming from fuel return from high-pressure pump not from common rail and injector return.
    Can You tell me where is shut-off valve and how it looks like? Some pictures, please?
    May 2018
    Ukraine
    At wich points the return flow was measured?
    Sep 2020
    Hello, because I have exactly the same car with the same problem, can anyone tell me how the problem was solved?
