pincode.... 00182
Hello! Someone would please help me with the pincode of a vw derby (mexico), i did some search and i found out that this car is similar to a polo classic, thing is the ecm shorted because of water leaks, now i'm trying to change it but i need the pincode. I read the immo-box, please and thanks in advance.
VW Derby 1.8L 2008
eeprom 24c04
left-hand drive
standard
pincode.... 00182
Help without something in return and you will be helped if you need help...
Cazalvalf (19th February, 2019), silverfox64 (7th February, 2020)
Yes pin code is 00182 HEX = B600 unsigned 182 = 00182
Thank you guys, right now i'm at work, but later i'll try it and let you know. Thanks again!
Edit:
It worked perfectly fine. thanks guys!
