Results 1 to 4 of 4
    diagtech2000's Avatar
    Jul 2013
    North of England
    Default nissan nv200 9s12x 2012(62)
    hello,
    pictures attached of a 2012 nissan nv200 with a 9s12x on it,
    does anyone have a wiring/connection diagram for this 9s12x please?
    cheers
    Please hit thanks if this helped you!
    dashradio's Avatar
    Inafield
    This should be able to be done from the 6 test pins
    • First, locate the .............Ground
    • Opposite of Ground is ..BDM
    • Beside the Ground is.... Reset
    • Beside the Reset is .......5 Volt
  3. The Following User Says Thank You to dashradio For This Useful Post:
    diagtech2000 (20th February, 2019)
    Jul 2013
    North of England
    cheers pal, hows the best way to locate ground?
    multimeter continuity test between the PCB & the 6 test pins you circled?
    dashradio's Avatar
    Inafield
    Quote Originally Posted by diagtech2000 View Post
    Yes, just use a multimeter, find earth first, then the rest are always in the same place.
  6. The Following User Says Thank You to dashradio For This Useful Post:
    diagtech2000 (23rd February, 2019)
