Ive done a few of these with Lonsdor AKL under INSIGNIA so i would have thought that Truecode or Smok would connect, Im unsure about the remote but will be interested in the result.
Hi DK members
Yesterday had a astra j 2012 akl.
Tried first truecode to get pin and program key but would not connect.
Tried to get pin with smok and same,no connection.customer had to leave and I took the bcm out and read 25160 and added key by dump with tango.
Will go later to put everything back and check if working.
Now will remote work even if I added key by dump?
Why truecode or smok could not communicate with bcm? because akl?done a few spare but no akl..
If i helped please press the thanks button
comizelu (21st February, 2019)
ive done loads of these all keys lost using abrites and truecode , akl isnt your problem
comizelu (21st February, 2019), nenadgorgi (21st February, 2019)
Remote should work too. Akl have no influence on access to bcm. You have some kind of problem at car. On uhds you get init error msg?
Init error mean by all cases that is problem with connection at all.
Im done last time Astra J - add key. BCM out, add key by Tango, mount back - car start, but no remote. Then im again add key using SKP1000 and PIN - remote work OK. Try add key again using OPCOM.
