Results 1 to 4 of 4
    Feb 2019
    Question ori files DCM 3.5 - manual transmission - or tunning to manual - Ford
    I changed the gearbox from Automatic to Manual. Now, starter not working. If I put + on starter, everything is ok.
    I want to reflash the ECU with ori files from manual transmission or if you know what to change into current software will be great.
    Can someone give me the ori files from a DCM 3.5, manual transmission, 140 hp? Ktag, galletto, kess
    Many thanks in advance.
    Feb 2016
    Please, Ford Kuga and Mondeo with manual transmission. Read Kess V2.
  3. The Following User Says Thank You to dawidd3 For This Useful Post:
    FoObPro (22nd February, 2019)
    Sep 2016
    In ford writing by obd other maps destroy this ecu, You must change coding in bcm and etc......
    FILE SERVICE
  5. The Following User Says Thank You to voltechcar For This Useful Post:
  6. #4
    Feb 2019
    Thank you @dawidd3.
    @voltechar I changed in BCM the gearbox, gearbox type, driving ratio and the starter doesn't work. I have a DTC U0101 Lost communications with TCM.
    I changed the wires for manual. If I am writing with kess, ktag is still destroying the ecu? I have also a vcm2 (ids 105), is this helping me?
