Results 1 to 8 of 8
    Nov 2011
    Romania
    Default fiat egr off help
    hy guys , can you help me please whit an egr and dtc p2231 off for this car , the car is fiat fiorino 1.3 ecu is mareli mjd6f3 , i have made a file the car runs ok but i got mil light in dash and no dtc on diag, i have atached both files
    Oct 2017
    egr off tested solution
    Oct 2017
    and about p2231 you must disconnect o2 sensor and remove dpf
    Nov 2011
    Romania
    i have delete p 2231 on your file and the same storyn no dtc but mil light in dash...
    Aug 2018
    Nederland
    Default egr dtc off
    Quote Originally Posted by Tzepy View Post
    pleas pm for pasword and thanks my
    no spam in sigs !!!
  6. The Following User Says Thank You to ecuworks For This Useful Post:
    Tzepy (21st February, 2019)
    Nov 2011
    Romania
    please upload again . the file is empty
    Oct 2017
    CAN YOU REMOVE DPF FROM FILE AND RESET IT BEFORE WRITE FILE
    TuningInside83's Avatar
    Dec 2016
    Italy
    Your egr is properly closed in your file. the problem of the dtc is another thing. Does the car have the DPF? Check the sensors. Do you have the same problem with an original file or not?
