Results 1 to 4 of 4
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Default Fiat Qubo 1.4i MM IAW 9GF CAT LAMBDA OFF
    Hi mates!
    Anyone can make CAT LAMBDA OFF on MM IAW 9GF? This is gasoline engine, 1.4
    I never did this ECU before...
    HW: MM9GFHW003
    SW: 4L13_Q10
    Spare: 52032676
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Any ideas?
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    yes your file
    pass PM
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  4. The Following 2 Users Say Thank You to boomeer For This Useful Post:
    eculevel (23rd February, 2019), Inquizit0r (22nd February, 2019)
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Read/Write by KESS 5.017.
    No CAT, Lambda DTCs - all ok. But engine start only one time. Than - DTC P0605 - Internal ECU memory. And no start till DTC erase. Than one start again.
    What is problem? Kess? File?
