Results 1 to 9 of 9
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    47
    Downloads
    68
    Uploads
    Default Ligier JS50 2016
    dont have eeprom , have MCU 9S08AW32 , place on pbc for 24c04 is empty , maybe ecouse is new mcu inside
    read on bdm pins
    original km 72548
    need 14351km
    drpeter's Avatar
    The Netherlands
    379
    Downloads
    32
    Uploads
    Quote Originally Posted by markony79 View Post
    read on bdm pins
    original km 72548
    need 14351km
    drive 10 km post again.
    carhexedit
    Jan 2009
    Sweden
    47
    Downloads
    68
    Uploads
    yes, i will do it , i just wait to get the car here, i was get only dash
    p.s. i see you was did almost same dash , but in your dash was have 24c04 , in mine dont have
    is it same pcb like mine ? did you save photo from your pcb ?
    regards
    M
    drpeter's Avatar
    The Netherlands
    379
    Downloads
    32
    Uploads
    regards
    M
    Sorry no photo
    carhexedit
    Jan 2009
    Sweden
    47
    Downloads
    68
    Uploads
    check now here
    i drive the car , more then 100km
    and post bouth files
    need around 14000km
    drpeter's Avatar
    The Netherlands
    379
    Downloads
    32
    Uploads
    check now here
    need around 14000km
    Are you sure this is the same car? very nasty one. will take some time.
    carhexedit
    Jan 2009
    Sweden
    47
    Downloads
    68
    Uploads
    check the photo
    or , i will solder one eeprom 24c04 on the place on pcb IC5 , powerr up the dash ,and wait maybe the MCU will write some dump in 24c04
    older dash have the 24c04 on this place
    i wil try it
    in mcu is to many bytes changed after drive it car
    drpeter's Avatar
    The Netherlands
    379
    Downloads
    32
    Uploads
    check the photo
    i wil try it
    yes you can try, this looks like a random code generator :-).
    carhexedit
  9. The Following User Says Thank You to drpeter For This Useful Post:
    markony79 (15th March, 2019)
  10. #9
    Jan 2009
    Sweden
    47
    Downloads
    68
    Uploads
    everything work good, but after i read out 24c04 its still empty ,
    no solutions fot this ... i will try drive now only 1km , and check it
    Dr Peter, Thanks for your support
