Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 77
Thread: DDRS Help!
  1. #16
    I used the crack from this thread (DDRS CRACK 6X OR 7X) but can't get it to work.
  2. #17
    makura's Avatar
    Quote Originally Posted by kenworthtrucker View Post
    I have the same problem with ddrs 6.10,i have dddl 6.4 running ok on my laptop,i installed ddrs 6.10,took the crack file drssec.dll and pasted in in c/program files/detroit diesel/ddecreprograming and chose to replace old file with the new one,restarted the computer.
    But still i get the same massage,''Unknown hardware key supplier''
    am i using the right crack or my cracking method is not up to scratch?
  3. #18
    You must install the software in a xp SO and also you must install first DDRS and then DDDL and remember crack it and then restart your computer
  4. #19
    Member anthonycorsi's Avatar
    venezuela
    hi i have the same problem with my DDRS, when i try to run the program, it pop's a windows saying "unknow hardware key supplier" i have DDRS 6.10
  5. #20
    SOmebody knows the possible reason that the DDRS or Cal Tool work so slow and the most of time get freez?
  6. #21
    Default mmmmm
    Quote Originally Posted by hercamp View Post
    HI DK FRIENDS
    I have a big problem with ddrs...that I have never have...I tried to reprogram an ecm of 60?s series detroit ddec III .....the ecm rating was 300 hp ...and I want to work in a 500 hp engine ....when I put the 500 hp in ecm the program say program not compatible with ecm hardware...after that I try with other calibration for 430 hp the calibration download to FRAM...when dounload 100% appear the message INVALID checksum CODE FRAM
    code : 0xddc0xxxxxxx
    and now I cant turn on engine because delete the initial calibration I guess....hwo works whit ddrs?
    hwo can download some calibrations to try to turn on the engine ?
    many thanks
    just use the ddct and change from boot memory to vector memory hahahaha
  7. #22
    i have ddrs dddl and ddct working great in the same computer, i can make magic with ecm?s thanks everyone in forums
  8. #23
    DK Veteran hercamp's Avatar
    Talking
    Quote Originally Posted by topitopi View Post
    in that time I havent had dct ...and without that was impossible...now its solve ...but when u have an ecm blank u cant get vector room...only boot mode ,download program in dct and program ecm and program with mainframe data...but didnt works.
  9. #24
    Member Texas149's Avatar
    USA
    I have a problem with ddrs. When I hook up to a DDEC VI, the auto connect fails and kicks back with a authorization level too low. I suspect license level is too low as read/write levels are at 2. Anyone have a solution for this?
  10. #25
    DK Veteran RSwire's Avatar
    your girlfriends house
    Did you try a new key with higher read/wright level?
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  11. #26
    USA
    Dont have a new key. I used the same license file crack as I used for DRS. Is there another one or can someone create a key for me?
  12. #27
    has anyone figured out,the Unknown hardware key supplier? problem and solution...unable to find any
  13. #28
    Top Poster Juanincho's Avatar
    Aug 2010
    The unknown hardware supply key error happened to me with ddrs 6.10 and 6.14, it was a corrupted ddrssec.dll , so I got the correct one from the ddrs thread and the soft is working for me now.
    Check this thread: http://www.digital-kaos.co.uk/forums...k-6x-7x-64991/
    Last edited by Juanincho; 15th November, 2010 at 11:01 PM. Reason: Adding thread address
  14. #29
    Quote Originally Posted by Juanincho View Post
    The unknown hardware supply key error happened to me with ddrs 6.10 and 6.14, it was a corrupted ddrssec.dll , so I got the correct one from the ddrs thread and rhe soft is working for me now.
    yes links are dead could really use 6.x 7.x crack
    bnolann
  15. #30
    USA
    Default Thread Bump!
    BUMP!!!! Yes we could really use this.....Anyone?
