Use sentinelkeyw.dll for both DDRS 6 and DDRS 7, just copy and replace in their respective folders. (Thanks to jabkissmya for help)![]()
posted once and ill post again, engineering access for ddrs and drs, only works on 7.03 and down., on drs works to current 6.15. just copy and replace to corresponding folders.
http://rapidshare.com/files/40370470...lKeyW.dll.html
Hi all was wonder if someone might be able to help me out ?
Im having problems getting DDRS 6.14 running properly.
When i try to run it i get an error+cddc0022 then other errors saying
MBE\Fuelmaps does not exist do you want to create it when i select yes it says path was not found reinstall program
also say MBE\UNITS and MBE\VEPS does not exist and do i want to create them.
when it gets past all these errors it opens fine and connects to ecm but when i try to select Update calibration at DDc it says the path doesn't exist..
ive tried this on 2 different laptops both with DDDL 6/14 installed cracked and running fine but they are using a DDDL 5.04 crack could this be a problem maybe?
or is the program not Vista compatible maybe...
Thankyou in advace for any help..
hi dk bois i am new on forum i am glad find this forum sorry by my enghis iam big trobe my ecm is boot mode and i downtloade calibration to fram and error show invalid checksum code fram i check ddct to ghange from boot memory to vector memory and dont now doet help help please i now your hare genius thank.............
my ecm is ddc 3 serie sc6003qg ecm software level 4.0 edit version 41 rating group 6n4m= 6430 rating fam 6n4d =6013 application fam 6n4c=101 engine s/n 06r0255097 i need a cal please some body help apreciate moch
Hi buddy if you need a cal file check here http://www.digital-kaos.co.uk/forums...-files-173317/
only if you try to install DDDL7x and DRS7x...thats not possible becaus are same programs....
the life is easy... people complicate!!!!!!!!
life is funny just step away of people that wants make your life a shixx
http://youtu.be/PEw3nYmpEys
this may work in Windows 7 or that can work with 7
Good afternoon.
anyone can tell me referred to the message "unknow hardware key suplier"?. for drs 6.10
I think you need the "Factory Crack" Try the thread below, I think you will find the answer.
http://www.digital-kaos.co.uk/forums...t-w-mbe-65833/
Elfer (22nd November, 2014)
I tried to install DRS and it just flashes then goes away when I try and open it.I used the crack and think I did it properly,all the folders etc are in the program folder etc.it just will not open. I do not have a data cable yet I was just trying to install the programs so I will be ready when that time comes. Could not having the computer connected to a ECM be why the program will not open? I installed DCT and it opens fine as well as Diagnostic link. I want to change DDEC 3 and 4 ECM files ,Did I download the right DRS? Thanks guy's I am reading and trying to learn. I really do appreciate what you guys are doing here,Thanks.
That's what happened to me when trying to install DRS in Windows 7. If you are using Windows 7 I think you will have to install DRS in XP mode before it will work or on a computer with XP, XP Pro is best. I have read about this problem somewhere in DK. There maybe another answer if Windows 7 is not your problem. Maybe other DK nenbers will have a solution. And for me DRS will not completely open unless I am connected to an ECM.
Emgo
when it says program not compatible is because maybe you are installing a DDEC IV in a DDEC III
or the other way a DDEC III in a DDEC IV.
I had the same problem with reprogramming alll DDEC III at 99 % says invalid checksum FRAM that problem is a file corruption in your calibrations. try deleting all the calibrations and unzip the RAR and the problem is solved.
I am usig windows 7 I will try and see if I can make it recognize xp.I would think that the newer windows versions would recognize older versions better.
