Results 1 to 9 of 9
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Default Fiat Stilo Magneti Marreli Radio and Navy 735297003 code
    Hello m8s.Please,calculate code for this radio.Thanks in advance.
    Raimax's Avatar
    Nov 2013
    LT
    code is 6x84
    No second number visible
    maybe 6384
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  3. The Following 4 Users Say Thank You to Raimax For This Useful Post:
    masterskay62 (23rd February, 2019), MOBILTRONIC (23rd February, 2019), shooting (24th February, 2019), smoggy (23rd February, 2019)
    Thanks for reply but please confirmed this code,...OK?Thanks in advance.
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by MOBILTRONIC View Post
    Noone can, you need to re-read your TOP flash as it's a damaged read
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  6. The Following 2 Users Say Thank You to shooting For This Useful Post:
    MOBILTRONIC (25th February, 2019), Raimax (24th February, 2019)
  7. #5
    Ok,m8,...I read Top flash once again.I post file as soon as possible.Best regards.
  8. #6
    Hello M8s,...I read the flash again and compared it to the previous file,...100 % is the same file,....If there is any other solution I would like to hear.Thanks in advance.
  9. #7
    shooting's Avatar
    Feb 2010
    WALES
    Code is 6B84 .. you need to clean chip and read again
    wbr
  10. #8
    Raimax's Avatar
    Nov 2013
    LT
    You don't value my efforts. I gave the code. Did you check it out? No. What doesn't let you check?
  11. The Following 2 Users Say Thank You to Raimax For This Useful Post:
    MOBILTRONIC (28th February, 2019), shooting (28th February, 2019)
  12. #9
    Not my friend. I've made your recommendation, but I have to be sure I do not mount the memory several times on pcb. I've tried read it flash memory and it's always the same.I'll test your code,so we'll see where we are.Thanks for help anyway.Best regards.
