    Jan 2018
    shaftesbury,Dorset,UK
    Default Can anyone add popcorn or Hardcut limiter to SAAB 9-3 1900TID
    Hello
    I am unsure on this ecu how to add it to limiters, I have had a good look through but unable to locate maps to add it to. Also I feel the fuel can be turned up a little bit for some black smoke we are running 100% straight pipe now. but hardcut or popcorn limiter is the aim here
    I do not have the original map as we never had it as we cannot read from the ECU but I have the software numbers and the modified file
    HW: 0281013807
    SW: 1037380261
    VIN nr.: YS3FB46V061134050
    SW ver.:
    Spare:
    Engine: Z19DT
    HW Ver.:
    SW upg.:
    Installation:
    mancioks's Avatar
    Feb 2017
    Germany
    What RPM you want limit?
    If i helped, don't forget push thanks + rep
    Jan 2018
    Quote Originally Posted by mancioks View Post
    4500 mate if you can. legend
    mancioks's Avatar
    Feb 2017
    Germany
    here u go
  5. The Following 2 Users Say Thank You to mancioks For This Useful Post:
    kennyash1 (23rd February, 2019), leotdx (2nd March, 2019)
    Jan 2018
    thank you for your time mate. rep has been added. thanks
    mancioks's Avatar
    Feb 2017
    Germany
    Can u clean your inbox?
