agat8 (19th January, 2020), CHAMO (18th March, 2020), diagprog (9th December, 2021), mahmoud122 (23rd March, 2021), odokor (20th July, 2019), patpuku (18th September, 2019), pinotec (22nd November, 2021), ZIOMAL4340 (22nd December, 2021)
Please for help in my case. I did stupid thing - read flash by obd2 injectors coding gone ) I'd tryed use option in galletto codin can but no result.. i couldn't write codes. Is chance write codes in eeprom manual? in .rar is eeprom without codes and file with codes. THANKS
8H8O3SG- 1 FROM GEARBOX
8IHK5WG-2
71HV3WE-3
8SHT8IF-4
Help please
Did You try to write the injector codes with diagnostic equipment? If the car starts, and the only injector codes are lost, you should be able to input those codes with diagnostic equipment.
3inferno3 (26th February, 2019)
Yes i tryed write file with my codes but i couldn't write it... i have two errors first is bad coded injectors and chain immu. this happend after write flash by obd. coding injector was gone launch x431 didn't code. maybe kts or other diagnostic tool?
any diagnostic will not write coding if immo lost
car starting or not...........probably not but give answer
need help
now my goal is to buy xp-005
who will help?
Keyless or normal key?
Had these problems with same ECU EDC16CP33, just on Qashqai (with keyless system...). You won't be able to adapt injectors when you have probems with IMMO - "chain immu", first adapt keys/ecu with launch. When you choose Nissan, when first screen pop's up after bt is connected you should go to special functions or coding, and adapt the ecu, after immo is sorted and car starts, then you can write injector codes with diagnostic equipment Had this problem, sorted with Launch X431 without problems
if keylees so remember swtch ignition on by blade of key
need help
who will help?
SOLVED trHANKS FOR ALL here. with hez editor i edit my corrupted eeprom some things add some delete... atlast was one error bad coding injectors with launch write codes ( first not from gearbox like in renault ) 1 is from time belt .. and car start without problem :P thanks again!
justin1987 (26th August, 2020), rafal (26th February, 2019)
May be you share your solution to others? We very glad to see that you did it. But we also be thankfull to you, if you post your work here.
can do virgin? and program the unit again, while recovering the loss
Once I wrote down the injectors in flash. restored with ecm opening, while there was fullflash bottom ecm
abdomm (6th May, 2020), alexline (21st December, 2023), AlimK (25th November, 2022), andro822 (12th May, 2020), autoepc12 (21st April, 2023), baltazar3 (4th July, 2022), busaman (27th December, 2019), buul (22nd February, 2024), CHAMO (17th March, 2020), crazylou2017 (25th May, 2019), credoline (1st April, 2020), danielslimovschi (18th September, 2019), darwins (20th August, 2019), dawidhubert (22nd December, 2022), diagprog (8th December, 2021), djbpm (22nd May, 2023), ecurepairpl (13th February, 2021), fedji23 (23rd December, 2022), hellmet (20th December, 2022), ilekim (12th April, 2021), InfoPerformance (28th May, 2019), Inquizit0r (13th April, 2022), Jacob6969 (5th December, 2023), justin1987 (25th August, 2020), kamil1555 (5th January, 2023), kareszka (8th June, 2022), karimdz (17th February, 2022), ker0sin (22nd September, 2022), Kevin 2304 (18th August, 2020), kostovski13 (26th May, 2019), kotarski88 (2nd September, 2023), kumbari (11th November, 2023), lele89ca (1st May, 2021), magdex (18th November, 2021), mahmoud122 (22nd March, 2021), marouane (17th November, 2021), micost (2nd February, 2024), morfej (4th November, 2022), mpsgsm (12th February, 2020), Mrpromega (25th October, 2022), nbtechnic (2nd July, 2019), nemena (15th December, 2020), notm (13th September, 2019), NTec (8th June, 2020), odokor (15th July, 2019), ordorika (10th February, 2022), oskars268 (16th May, 2023), paskizo (14th March, 2021), patpuku (17th September, 2019), pinotec (22nd November, 2021), rafal (29th October, 2019), Retter (19th November, 2022), ruben baez (29th September, 2021), sdade86 (3rd January, 2020), sdtsedat (24th May, 2019), sehack (23rd August, 2023), smdoto (22nd March, 2021), sofman (23rd January, 2024), stoilgalabov (19th August, 2019), subas (2nd June, 2023), thurgau (10th August, 2019), Tjur80 (24th July, 2023), vendetti (21st May, 2021), wiatajek (29th August, 2023), wissamshaat (19th September, 2020), YushiMika (28th November, 2022)
CHAMO (18th March, 2020), chipdanix (27th February, 2019), dawidhubert (22nd December, 2022), ker0sin (22nd September, 2022), thurgau (10th August, 2019)
