hi all found this forum while looking for help with my volvo s60 d5 2005 remapping
i have a mpps and tried to read ecu not found i read it needs to be in boot mode is this correct ? any help would be great
code on ecu is 0281 012 103
ECU = EDC16C31 old ecu are EDC15c2
volvopedz (23rd February, 2019)
the mpps i have is the only tool i have do i need another tool ?
check your mpps SW version...? V16 and V18 will do it...
you should connect it direct on bench with 12V... checkout pinout for this edc...
When I help you press Thanks and Reputation...
volvopedz (24th February, 2019)
No need bench you can read it via obd just add K line from ecu. If Im not mistaken pin 43 from ecu (small plug) to pin 7 in obd port, but search te internet there are pinouts for that ecu.
Yes, Insert needle in pin 43 in the socket from the ecu and the other side of the needle (with cable) insert in pin 7 from the obd socket. Put MPPS or other tool (i use fgtech clone) and they will read obd.
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Little up date I tried the cable from pin 7 odb to pin 43 and I still get ECU not found odb is connected as it tells me there is voltage .
Hello there,i drive a s80 I 2006, 2.4 D5 163hp. In kess listed its a edc16c31,but its a edc15c11.its wrong listed,so i have done it in protocols under Bosch ME7.1.1 29F400 or 800 (its the same family number 114). Ive connected the ecu directly as shown on the pictures,and the eeprom pin 24 i think-its marked on picture,connected to ground with a 10kohm ressistor,without resistor it wont go into boot mode.... I dont know how it goes with mpps, but i hope this will help you,if its the same ecu
And power supply should be stable,ive done with a laboratory power supply on 13,2 volts or so![]()
