Results 1 to 3 of 3
    Aug 2012
    Default SUZUKI Jimny 2008 Remote learning
    Hi guys
    I cannot find any manula about remote programming for SUZUKI Jimny 2008
    This procedure does not work
    1) Confirm that the vehicle is the following conditions.
    • All doors are closed.
    • Ignition key is out of ignition switch.
    • Driver side door is unlocked.
    2) Disconnect negative (-) cable from battery.
    3) After 30 seconds, perform the following procedure within 60
    seconds.
    a) Connect negative (-) cable to battery.
    b) Operate driver side door knob switch from lock to unlock.
    c) Push “LOCK” button on transmitter and confirm that are
    operated from lock to unlock.
    d) Push driver side door knob switch to lock position.
    e) Push “LOCK” button on transmitter twice and confirm that
    all doors are operated from unlock to lock. With this, code
    registration is completed.
    I also did try this one:
    1. Switch ignition OFF and close all doors.
    2. Open drivers door and switch ignition on
    3. Switch ignition OFF
    4. Press and release drivers door ajar switch 3 times
    5. Switch ignition ON and then OFF
    6. Press and hold each button of the remote in turn for 5 seconds each
    7. Central locking should activate
    8. Press remote control lock button
    9. Maximum of 2 remotes possible
    Feb 2018
    try this
    b) Operate driver side door knob twise switch from lock to unlock.
    Jan 2017
    USA ����
    if you are using the electrical switch control for lock/unlock try moving the actual physical lock back and forth instead
    The thanks button is HERE looks like this --->>> THANKS
